billsnuff said:
Thanks, billsnuff, that answers my question. FHA doesn't require much.
I went to the house today and an HI had written up open grounds, no GFCI in kitchen or bath, no smokes in bedrooms or adjoining hall and one receptacle dead in living room.
There were 4 20A circuits ran from a fairly new service panel inside to the old panel which was gutted and used as a j-box. The 4 circuits were tied into the old 2-wire NM. Owner didn't want to re-wire so I put GFCI breakers on 3 of the circuits and an AFCI breaker on the other. I fed the AFCI circuit thru a GFCI receptacle and tapped that circuit at the hall light to feed the 4 new smokes. Put the little stickers on the receptacles and called it a morning.
Oh, yeah. The dead receptacle in the living room most of you have figured out.
I turned the switch on!
