6985741
- Owensboro Kentucky
- Electrician
arguing again with someone who says cat 6 is faster than fiber optic. I argue fiber runs at the speed of light with more gigs and they say it has to much light resistance.
LMAO. I bet they are also some of the ones that are arguing that 5G cell towers are causing Covid.......they say it has to much light resistance.
Apples and oranges. The speed at which a waveform moves through a medium is a different consideration from how high a frequency that waveform can be. When you compare "speed" of communication through fiber vs copper, it is the latter you are talking about, not the former. The speed of waveform propagation is pretty much the same for copper and fiber.arguing again with someone who says cat 6 is faster than fiber optic. I argue fiber runs at the speed of light with more gigs and they say it has to much light resistance.
Start with the speed of electromagnetic waves in copper cable is less than that in glass or plastic fiber (usually 65-75%). Then add high-frequency roll-off in the copper cables, which limits the information transfer.
The signal might be faster, but if either end can't support the bandwidth that the fiber can, it just does not matter much.So which is faster? Depends on what "faster" means. For 1G-baseT and 10G-baseT, the fiber will be marginally faster over lengths supported by the Ethernet signalling.
Fiber is faster and goes longer distances. We wouldn't be spending all the time, money, and hassle splicing on glass if copper would work.
For short (
Fiber is also nice if you think ground isn't going to stay the same between sites. Like between the shop out back and the
main house, especially in areas with a lot of lightning.
For the rest of the local, in building stuff, it's probably a waste of money.
T3
