deb4523
- Alaska, USA
Hi Guys,
I am looking at installing a signal booster on a building for improved cell phone signal inside the building. The system the end users would like to have installed has an antenna with a low temperature rating of -22F. Our winter temperatures regularly get into the -50's F. When I spoke with a company rep on the hone they thought the reason for the low temperature rating might be the fact that it is made with fiberglass and may be brittle at colder temperatures.
Is there any other reason why an antenna would not work in cold temperatures?
The only other appropriate system I found had an antenna rating of -40F, so better, but still not at our normal specs.
I can't see a fiberglass antenna exploding at cold temperatures, but I could see it warping or possibly shattering with wind or if it were hit with something. Does anyone have any experience with this?
Thanks,
Debbie
Thanks,
Debbie
