Richard Franklin
Hello, I have a customer that wants to replace the existing lighting and wiring in a fiberglass boat hull/deck repair temporary building. The building is a quanson hut style structure with canvas sides, galvanized metal tube frame, 20 feet wide, 50 feet length and 20 feet height. When the boat is temporarly positioned in the building, there would be about 4 feet clearance from the upper ceiling framework. The current wiring method is 2-tube strip fixtures mounted horizontally along the building lenth, with portable power cords thru-out fed from wall mounted GFI receptacles and a standard exhaust fan which is end mounted near the floor.
I'm believe that this temporary building used for fiberglass boat repairs would fall under the NEC Hazardous/Classified wiring chapters for the code recognized wiring method. Does anyone have any input in the required wiring of this type facility per the NEC? Thanks... Rick
