fandi
- Los Angeles
- Electrical Engineer
Hello All,
There's an inverter connects to 1) grid tie main service panel, 2) solar PV panels and 3) Energy Storage System (ESS).
The inverter is UL1741, UL 1778 listed. The manufacturer diagram shows connections like mention above. Keep in mind that there's no specific ESS type mentioned other than the only requirement of ESS to be 48V.
The ESS is Lithium Ferro Phosphate (LFP) technology and UL1973 listed.
Solar PV panels is UL1703, UL2703 listed.
So basically each component of the system is listed individually.
Is there anywhere in UL9540 that requires third party field evaluation to make sure these individual components tested to work together?
Thanks.
Thanks.
