jcp198
New member
- Pittsburgh, PA
Hello,
I'm currently designing a flow system that will be taking in Class 1 Div 2 rated gas samples. All the equipment, i.e. relays, gas detectors, heater, PLC are all Class 1 Div 2 rated. I'm using sealers for the gas detectors, through the sealers will be 24VDC, grounding circuit (reset button), 4-20mA output, and relay outputs. I'm using PLTC wire for all of that wiring. My questions is, wire that is not transitioning from class 1 div 2 area, does it still need to follow NEC 501.10(B) or would it fall under nonincendive field wiring? All of this is also going to be inside of an enclosure if that makes a difference.
Regards,
Regards,
