mbrooke
Batteries Included
- United States
- Technician
Why does the CEC require that 3 pole outlets on an ungrounded GFCI circuit have their ground hole blocked? Or am I just reading it wrong?
????Why does the CEC require that 3 pole outlets on an ungrounded GFCI circuit have their ground hole blocked? Or am I just reading it wrong?
EDIT In older versions its 26-700 (8)Notwithstanding Subrule 1), at existing outlets where a bonding means does not exist in the outlet
box, grounding-type receptacles shall be permitted to be installed, provided that each receptacle is
protected by a ground fault circuit interrupter of the Class A type.
I looked back many years ( I have almost every edition) and found nothing.What about older versions of the CEC?
There is no such code in the CEC and never was.Here is one such example:
Googling ungrounded outlets in Canadian forums mentions similar statements.
Your quote is from a home inspector. Notice there is no reference to an actual code?
don’t take code advice from a home inspector.
