Mojosmantra
- Miami, FL
Failed inspection. Residential addition in South Florida. I'm the owner/builder and architect (it's ok if you hate me
) Concrete block walls with 3/4" furing strips. Boxes are fastened to furing and set into Knock-outs in the block. Electrician mortared the boxes in after install, which is typical here, but is the root of my question. Problem is he also mortared in the Romex. Inspector instructed him to "protect" the romex with duct tape.
I understand 334.12 (b) doesn't allow the embedment of romex. Is it a reasonable solution that duct tape will cause the romex to no longer be "embedded"? Doesn't seem right to me. And What Is the purpose of mortaring in the boxes even though they are securely fastened to the furing. I read 314.21, but does it apply in this situation - or does in really apply to the finished drywall surface?
As of now, the boxes have been removed and the romex duct taped on the ends - and re fastened. However, in lieu of sealing the boxes over the romex, I sealed the holes behind the boxes with mortar (yes, a lot of work). I do not want to re mortar the boxes - just seems sloppy and contrary to the NEC embedment provision.
Wondering what the inspector will have to say...Any opinion or advice? Thanks.
