nbabcock03
- Des Moines, Iowa
- Apprentice Electrician
When finding resistance for a problem like voltage drop, and the conductor type is unspecified, which column of Chapter 9 Table 8 is to be used when searching for ohm/kFT. I assume copper unless otherwise specified to be aluminum. I am unsure whether to use uncoated/coated and solid/stranded when the conductor is not specified in the problem.
For example, when solving;
What's the voltage drop of two 12 AWG conductors that supply a 10A, 120V, single-phase load located 100 ft from the power supply?
With VD = I x R
How would I find the resistance of my 12 AWG conductors?
With VD = I x R
