flightline
Ya? know, sometimes you can really learn something from these forums that sticks in your mind. On a prior thread about low-voltage under/over cabinet lighting, I was reminded about the restriction with respect to putting low voltage wiring within walls, [Article 411]. That has always stuck with me.
So I was surprised to read an article in ? Fine Homebuilding ?, written by a Robert C. Grey, an electrician working in Brookfield Conn. If you subscribe, it is on pages 62 through 66.
There were some things that I felt were not correct in the article. While I do not have my current NEC at hand when writing this, I do have my Chicago Electrical Code and I?m pretty sure these are comparable articles. The first thing that I believe incorrect is the author?s statement: ? Don?t put lights on a 20-amp circuit ?. ? When tapping into the power source, keep in mind that the National Electrical Code (NEC) requires lighting to be on a 15-amp circuit ?. Is this not contradicted by 210.23 (a), 240-4, and especially 411.6?
Another problem is that the author suggests the use of landscape lighting cable be fished in the walls, ? rather than NM cable because the wire is smaller, is more flexible, and looks better ?. Fine reasons I?m sure but none of which seem to have the ability to contradict the rules of 411.4. What do you think?
What is worrisome is that, if I am correct in my understanding, then Fine Homebuilding and the author, Mr. Grey, are erroneously directing people who don?t know better to violate the code. Perhaps I?m all wet; that?s why I?d like your opinion. If you would like to contact Fine Homebuilding's [fh@taunton.com] editorial department, please feel free to do so.
