I've never heard of such a thing. Gobs of people mistake fine strand copper that's been tinned for aluminum.
I think I'm ok on tis issue. The stuff I'm looking for is copper colored on the outside of the wire.
I don't know that you could coat copper with aluminum, at least easily.
-Hal
I don't know how easy it is, but yep
While definitely NOT a product for NEC applications, I've found that most automobile jumper cables are what is called "CCA", copper coated aluminum. CHEAP way to have 4 AWG that is really more like 6 AWG copper and have customers not understand.
I've heard of that. Probably seen them and didn't know it. What I'm looking for is a lot bigger cross section and far better insulation. I suspect it won't be any cheaper than copper.
NEC mentions copper clad aluminum. Don't recall ever seeing any or know what it may have commonly been used for.
Would have been early 1970s, copper prices went through the roof. Aluminum #10 wire came out, but they were using a different alloy than common today and there were issues with connections. Copper clad Al #10 came out and it worked rather well, quite a bit cheaper than copper #12. I roped a couple of houses during that time period. Pounding the #10 into the small steel boxes was a pain, but it worked.
I don't remember the copper price, but it was enough that there was a short time when I heard people were collecting pennies and selling for scrap.
Thanks for the responses.
Still looking for a supplier.
