finished ceiling 20' high, recessed lights
Stevenfyeager
United States, Indiana
electrical contractor
Customer wants recessed can lights in a 20' high finished barn ceiling, How many lumens are available for LED trim kits? (Can type) What has worked for you?
Thank you.
Residential fixtures won't work well at 20'. I suspect you'll need commercial fixtures rather than residential. This is something I would model in a photometric program like AGI32 or Visual. You can contact the local rep agency for one of the major the lighting brands and they should be able to help. Your supply house should be able to put you in touch with the agency for brands that the supply house carries.
You could look at this thread:
Note the fixtures changed several times and the ones I finally installed are in post number 13, I really like them, lots of lumens.
