Fire Alarm Battery and Voltage Drop Calculations
BatmanisWatching1987
NJ
Jr. EE
I was wondering if anyone can help me learn how to do a Fire Alarm Battery Calculation using Honeywell MS-5UD-3 excel spreadsheet.
I have a main FACP panel (MS-5UD(E)/MS-10UD(E)). The basement to the 3rd floor each has 1 Pull Station (PS-DA and PS-SA), 5 Horn/Strobe (System Sensor Indoor Selectable- Output Horns, Strobes, and Horn Strobes for Wall Applications), 3 Combo Smoke and Carbon Detector (System Sensor i4 Series Combination CO/Photoelectric Smoke Detector) and 1 Strobe (System Sensor Indoor Selectable-Output Low Frequency Sounders and Low Frequency Sounder Strobes). But the problem I am having is I don't know how to fill out the excel spreadsheet properly.
Still looking for a voltage drop calculator spreadsheet I can use
Thank you for all your help.
Try downloading the software for the particular panel you are using. Most but not all have a battery calc built in when you are building your system through the software. Firelite link attached below
