boyle78
- new hampshire
I recently installed a new fire alarm booster with new cables to new devices. Everything tested like it should....until we noticed a trouble on the booster. It is so quick that the LED only "blips" on for a fraction of a second. We checked all the cable and all devices for loose connections etc. and found nothing. This install is for a working sheet metal fabrication factory. Impeding voltages, fluctuating frequencies and amperage loads from the various welders, cranes, cutters etc. were never a concern (obviously) and now may actually be causing the issue? We ran unshielded cable and only a small section of the runs are with in 5' of line voltage wires. I'm looking to see if anyone has ever had these issues and how should I go about trouble shooting this. I have gotten ahold of the customer support of the booster manufacturer and they agree that the facility itself with the numerous electrical needs could be to blame...but with no way to resolve it.
The trouble is showing up at the main FACP history, but not reporting to the monitoring company. It's totally random and only happens when the facility is doing business (which also points to voltage irregularities) I have used a data logger in the past and was thinking this would be a good place to start. Relocating the booster is an option, but if the source voltage is to blame it won't do any good. I have to wonder about the building bonding means and have not been able to research it. Any help would be cool!
