Last year on a project we had to change out a old NAC power supply panel. The old panel required 2.2k ohm resistors for EOL out in the field. The new panel states it requires 4.7k ohm resistors for EOL. When we changed these out the company who does the programming said you can leave the resistors as the 2.2 k ohm and it will work just fine. For the past 2 months we now get random troubles that show up, sometimes for 3 seconds sometimes for a few minutes. Of course whenever I go to troubleshoot everything is back in normal. Do you think having these 2.2k ohm resistors out in the field instead of the 4.7k ohm could be causing this or should that not be an issue?
