Interesting comment about the required DB level.
What they did not take into account is that some DB meters may have a different frequency response in the A setting than in the C setting. The frequency curve of the A weighting is as much as 5 db lower for the same sound power compared to the response for a frequency above 1kHz.
So if the manufacturer delivers the same sound power, a DB meter set to the A scale may incorrectly show that the level at a distance is too low.
Unless, of course, the UL standard specifies the use of A weighting only for both manufacturer and inspector.
