Chris3585
- Smyrna, Georgia
I was always under the impression that fire alarm wiring could not be in the same cable tray as other low voltage cabling. I have permitted contractors to strap the fire alarm cabling to the bottom of the cable tray, it just could not be inside the tray. Is this required by a code or standard? I can not find any requirement for Power Limited fire alarm circuits to be separate from other low voltage systems in the NEC.
Thank you,
Chris
Thank you,
Chris
