Alwayslearningelec
- NJ
- Estimator
If I remember correctly Class A is a return loop, Class B uses end of line resistors at the last device.Now this is confusing. Isn't the SLC(for addressable system) the initiating circuit?
Your correct. But they are SLC should be return and initiating should not be. I thought SLC was an initiating circuit.If I remember correctly Class A is a return loop, Class B uses end of line resistors at the last device.
My guess there is a SLC to a controller that is connected to multiple initiating and/or indicating devices.3.3.279 Signaling Line Circuit.
A circuit path between any combination of addressable appliances or devices, circuit interfaces, control units, or transmitters over which multiple system input signals or output signals or both are carried. (SIG-PRO)
