Can you provide more information, like where are you installing the fire alarm panel (i.e city & state), are there auxiliary panels for horn/strobe circuits, are there any engineer's specs for the equipment installation, etc. ? There are a number of answers that can be given here. You probably won't be able to get a std., off the shelf breaker under 15 amps but as Bob (iwire) mentioned the normal spec'd breaker used is a s/p 20 amp. Where did you get the D/P lockable type with surge suppression from ?
