ceb
- raeford,nc
Today I was in a large blue store, which I have named slowes, to purchase some caulking for a honey-do-project. While I was getting what I needed I noticed the display of fire caulk, right next to it was a display for fire blockage foam, same co. makes both products, both have same color labeling, wording every thing the same on both. The display for the foam claims 1 10oz. can = 15 tubes of fire caulk. Now in slowes 1 tube of fire caulk is in the $15.00 per tube range, this foam is in the $10.00 range, said to my self, self this may interesting. Then I read the disclaimer on the back of the can, it said in effect, "Not for industrial/commercial code applications. Check with AHJ before using. Not UL rated as fire stop. Not to be used as fire blockage". Then I said to self, this is a crock, other than to screw you out of money by buying something that from all appearances seems to be the same or equal to an approved product. I can see some one not taking the time to read the fine print, use it, only to be questioned by the inspector for its listing just to discover it is worthless
