I'm in the middle of a job, same type of fire damage. Here's the deal.
First, find out if the homeowner has a "code updates covered" clause in their policy.
Seperate the bid as, fire related, and code related.
The homeowner may be on the hook for the updates!
The code rules are this.....if a circuit was not correctly installed to the codes effective at the time installed.........YOU CANNOT REPAIR IT, it never was legal! You must make it to code! Everything you touch will have to be to code, some todays code, some the original code, depending on the depth of the repairs. You cannot reconnect any circuits that are improper.
Example, the house I'm doing has receptacles that are screwed to the wood paneling with no boxes. The circuit supplying them was fire damaged in the attic. I CANNOT repair the attic wire thus reconnecting unsafe and non compliant receptacles.
I get to rewire almost the whole house because it was the home runs that got damaged!
It's the only way the AHJ will allow. There's just no way you can repair an improperly installed system.
I make more money on the code updates, then the fire damage. And if there is update in the policy then it's all on the insurance company.
Also check with the AHJ, if they use the IBC for reconstruction, then the IBC states that todays standard for smoke detectors will apply. Smokes in every bedroom, and the hallway!
Rick
