Fire Proof panel
n240sxy
Is there a way to fireproof an existing recessed electrical panel in a corridor. The corridor will be fire rated
jatrottpe
NJ
Thermal Design Inc out of Houston Texas makes a fire proof product called KMASS which we use at the refinery for our fire proofing of emergency shutoff valves and assocaited JBOXes.
Perhaps you can make a custom panel cover that can be KMASSed and utilized. There website is http://www.tdius.com/
bphgravity
Florida
The most logical method is to 5-side drywall (fireblock) the sides and back of the panel cabinet space. This creates a rated void in the rated wall that the panel cabinet is to be located. This in effect elimanates the membrane penetration all together.
kwired
Electron manager
NE Nebraska
If you have no raceways or cables entering the cabinet this is easy but then what purpose would the cabinet serve:-?
e57
Hmmm.... A big envelope full o' small bills... :D Kidding....
Convince someone to build a rated wall assembly behind it. You could use the envelope for that... ;)
Or move the panel to the surface - wrap it in rock if you like to make it pretty.
