jubu94
- Troy, Michigan
This building has a primary utility service. Can I tap a separate feed from the owner's outdoor pad mount service entrance transformer to feed the normal side of the fire pump controller/ATS without a disconnecting means or overcurrent protection device? It seems that 695.4(A) will allow this. I guess I'm confused as to what is referred to as the service disconneting means. Is the service disconnecting means the owner's MV primary switch, or the main CB in the service entrance main distribution panel?
