I have a question with regards to a fire pump conductor and conduit sizing debate we are currently experiencing. The actual fire pump size is 75HP, 3PH, 208V, Wye. The jockey pump is a 1/3rdHP, same everything else. The distance from the main distribution board to the fire pump and jockey pump is 420'. The engineer has designed this on the plans with a 1600A Main circuit breaker, installed ahead of main switch in the main distribution board, and feeding it with four (4) four inch (4") conduits, each filled with three (3) 600kcMil, type RHH conductors, and one (1) 4/0kcMil, type RHH ground conductor. According to the 2002 NEC, section 695.4(B)(1) the overcurrent device need to be sized "to carry indefinitely the sum of the locked-rotor current of the fire pump motor(s) and the pressure maintenance pump motor(s) and the full load current of the associated fire pump accessory equipment when connected to this fire supply". This explains the main circuit breaker sizing, but according to the 2002 NEC, section 695.6(C)(1), the conductors will only need to be sized to "125% of the sum of the fire pump motor(s) and pressure maintenance motor(s) full-load current(s), and 100% of the associated fire pump accessory equipment?. According to my calculations, the FLA's of the fire pump and associated equipment is 267A, and even applying the 2002 NEC, section 695.7,voltage drop, we can not come up with the same conductor and conduit sizing as the engineer. Could someone please assist us as to the correct method to figure out the above situation? Thanking you in advance for your assistance.
edited by moderator to remove e-mail address. please use the PM function for private contacts
[ July 16, 2005, 10:20 AM: Message edited by: don_resqcapt19 ]
