Hello Everyone,
I'm reviewing a documents where the building and the utilities are owned by the government (it's a military base). the design indicates a unit substation consists of a primary switch gear (34.5KV), transformer (3.75MVA), and low voltage switchgear (6000A @480/277V). The drawing show the power connection to the fire pump is from the secondary side of the transformer via drawout breaker located in a separate vertical section (which I think this is violation of the NEC by feeding the fire pump from an overcurrent protections device). my questions:
1. shouldn't the power source be a head of the main MV switchgear breaker since this consider to be our service disconnect? If so, do we need to have a tap in MV section ahead of the main breaker or we can add another breaker in addition to the main to feed the fire pump?
2. I know the final say will be for the AHJ but can we feed the fire pump from the low voltage section (ahead of the 6000A main breaker)? This will save me from adding another transformer for the fire pump.
Thanks,
Thanks,
