Greetings Everyone.
Need help with some queries that i have.
I have a situation where i am adding a new Fire Water Transfer Pump to an existing MCC. The same MCC also feeds an existing Fire Water Pump. Inorder to avoid overloading of MCC, only one pump needs to run at the same time i.e an interlock between existing Fire Water Pump and new Fire Water Transfer Pump.
1. Does NEC mention anywhere about interlock for fire pump?
Fire Pump is very critical and needs to be running all the time. Does it make sense to have an interlock between the two Pumps? My client is very adamant about adding the interlock even though i told him that fire pump needs to be running constantly.
The existing Fire Pump has an ECS Fire Pump Controller (website name is mastercontrols.com). I spoke to one of their engineers and he told me the wiring for the fire pump controller cannot be tampered with or changed because its factory wired. He did give me an option of adding a slave relay to the customer terminals on the existing fire pump controller......Has anyone dealt with this kind of situation?
Any advise or suggestions would be highly appreciated.
Thank You
Thank You
