High rise building or hospital facility - The fire pump controller / ATS is fed out of utility transformer (normal power feed) and main emergency distribution panel (emergency power feed).
Main emergency distribution panel is fed from emergency generator.
Will the breaker (inside main emergency panel) serving fire pump and generator's main breaker need to be coordinated per NEC?
695.3(C)(3) won't apply to this case, I assume? Thank you.
