poweringtech
Isn't it dangerous if fire pumps are not required to have ground fault in a solidly grounded system of more than 150 volts to ground? The extremely high ground fault current may cause the fire pump to explode causing more problem than solution.
Excemption should be clear that if fire pump will have NO ground fault protection only if it is being supplied from an ungrounded system. Or an isolation transformer should be installed so that the system supplying the fire pump is either ungrounded or high impedance grounded to allow a single line to ground fault without damage to the fire pump.
