Hvactrician
- Walworth Cty Wisconsin
- Registered electrician
I have a 3000 amp service on commercial building. It also has a fire pump. The feeders for the fire pump go from the CT cabinet into the service entrance conductor portion of the main switch gear and run continuous into another conduit that feeds out to the fire pump room is this compliant with 695.3 A1 since the main breaker/ service disconnect is in a different vertical section of the switch gear?
