Installing a separate service to feed a fire pump controller which feeds a 60HP fire pump & jockey pump. The service will be coming from a utility Xfrmr, to a utility meter, then directly to the fire pump controller.
I assume a neutral will be coming from the meter along with 3 phase conductors. Does this neutral land in the controller? So the ground (sized per NEC 250.66) will come out of the pump controller grounding the neutral?
Then from the controller to the pump I will have 3 phase conductors + a EGC for the pump itself (no neutral)?
Thanks
Thanks
