I am hooking up a fire pump on a project. It has it's own service. The main fire pump and the jockey pump are the only 2 things this service is for. I do not have a main disconnect installed, rather each pump has it's own service rated disconnect. I have a wireway installed to tap the service entrance conductors.
The fire pump controller has a 150 amp service rated main breaker installed because it has to be sized 600 percent above the LRA of the pump which I understand. I have # 10 wire feeding the pump because the RLA is only 23.7 amps.
The jockey pump is is tiny, less than an amp, so I have a service rated disconnect with fuses feeding the jockey pump.
The ampacity of the entire load calculated at 100 percent of the LRA of the main fire pump and the jockey pump is less than 40 amps, so I have # 8 copper wire for service entrance conductors (that enter the wireway from the transformer). The inspector is telling me that the service entrance conductors have to be rated for the 150 amp disconnect in the fire pump controller, hence making them 2/0 copper conductors. I disagree with the inspector because this is a fire pump service, not a typical service.
Am I wrong?
Am I wrong?
