Fire Pump Multiple Sources
MNT
I have a fire pump with two sources. The first is the Utility service drop upstream of the disconnect, and the second is a standby generator with plenty of capacity. I know that a tap ahead of the on-site generator disconnecting means is not required, but is it OK to feed it from the same panel that is supplied from the generator ATS?
Thanks in advance for the help!
Wow! Thanks for the quick response.
1. The fire pump is for a fire sprinkler system in a school.
2. The panel backed up by the generator feeds some domestic water pumps, (also for the school).
