Cardinal
New member
- Soda Springs, Idaho
I am considering installing a non-fused disconnect switch on a fire pump circuit ahead of the pump controller but before the power source. The fire pump is 250 Hp and the jockey pump is 7.5 HP. Looking at NEC 695, it appears i need a 2000 amp disconnect! I am thinking that this only really applies to the overcurrent protection calculation. Since i have a non-fused disconnect, can i just size the safety switch to the combined motor HP? Do i need overcurrent protection?
The reason i want to do this is to allow our techs to service the fire pump controller and jockey pump controller without having to kill the main 480 volt transformer, which basically kills the plant. The existing configureation has the feeder cables for the fire pump and jockey pump coming directy off of the secondary of a 2500 KVA transformer. The arc flash rating is off the charts and we want to avoid any work at all with the power on but dont want to shut the plant down.
