Dark Sparky
- USA
- Electrical Engineer
Large building with separate Fire Pump Bldg located out in the parking lot. Fire Pump Bldg has 3 rooms - largest for fire pump, etc. - the other 2 rooms are a Restroom and a Janitor's Closet (both w/ their own outside entrances). There is a 480/277V panel, a 480-120/208V transformer, and a 208/120V panel - all located in the fire pump room. These feed loads including the Diesel Fire Pump Controller, a fire system jockey pump, a subpanel in a non-related bldg, and other non-fire loads.
Can the 2 panels and xfmr be located in the fire pump room? Code references? Looking for *any* code references - NEC, other NFPA codes, or any others - that may apply.
Thank you.
Thank you.
