Can a service to a fire pump be routed through a vault that contains the fire pump and controller?230.6(3) considers the conductors outside a building if installed in a vault.NEC 450.42 exception,states you only need 1 hour rating for vault walls,roof,and floors if sprinklered.In that case could the service conductors be routed from one side of the vault to the other side,about 30 feet away?
