Can a fire pump control panel be feed through a dry type step up transformer? A 75 hp 460 volt 3 ph fire pump with fire pump control panel feed through a 112.5 kva 208 to 460 volt dry boost transformer served from utility transformer. Does the dry type transformer need to be service rated? Electrical engineer specified the wrong voltage fire pump and now had the electrician install a boost transformer.
