Im looking at a generator replacement and the current setup has the generator feeding an emergency panel through a transfer switch and the fire pump controller through a manual transfer switch located in the same room as the main switchboard which supplies the normal power to the pump.
Im reading through article 695 and just wanted to clarify the correct installation. Im interpreting the following:
A) a manual transfer switch cannot be installed in the fire pump circuit
B) The allowable disconnecting means cannot be located in the same room as the normal distribution switchboard
C) the routing of the conductors from the generator to the fire pump controller cannot be located near the normal distribution board
Any input would be appreciated
Thanks
Thanks
