FIRE PUMP CONTROLLER IF REQUIRES TO HAVE A NUETRAL CONDUCTOR WITH THE UNGROUNDED AND EQC IN THE SAME FEEDER FROM THE GENERATOR PLESASE ADVISED ME WITH CODE ARTICLE AND ALSO BE IN COMPLAINT WITH 250.4 AT SAME TIME
ACCORDING WITH CITY INSEPCTOR WILL REQUIRE A NEUTRAL AND EQUIPMENT CONDUCTOR FROM GENSET AND BE CONNECT IN THE SAME LOCATION
BESIDE SERVICE FROM UTTILITY POWER WHICH BY 250.24 C REQUIRES A NUETRAL FOR SURE TO BOND INSIDE THE SERVICE SIDE OF THE FIRE PUMP CONTROLLER
PLESASE ADVISED
PLESASE ADVISED
