dross48
- anderson indiana
I have an apartment complex that is wanting me to mount a 200 amp disconnect outside with quick connects to be able to hook up a portable generator, in case of power outage, they are wanting a panel with certain loads to be applied there is also a fire pump that is being fed from power and light transformer the question is what are the requirements for this fire pump ? can I simply feed it through a manual transfer switch that is also supplying the panel?
