hi! I have a question regarding fire pumps. So, I am trying to figure out how to supply normal power to a fire pump. I have been looking through the code and am a little confused. For instance, it says that the fire pump can have a separate service or service tapped ahead of the building’s main disconnect. I understand that the utility provides power to the main panel or main disconnect. Is the fire pump’s power supply coming from the main panel or is it coming directly from the utility? Does it mean that that the fire pump’s power supply will be completely separate from the main panel, and is it connected to a separate breaker or is the main panel distributing power to the fire pump just in a different configuration? I am confused on how the fire pump can be supplied by an independent power source and am having a hard time visualizing it. I would appreciate your help!
