Fire Pump
ASPMANN
I have an existing fire pump 480 v 3 Phase 100 hp with jocky pump feed from a seperate service and transformer. The fire pump has a listed controler and the service is direct through a 200 amp meter base. My customer has up graded generators and wants to install the old one on the fire pump? Its more than enough in size 400 amps .I know that locked rotor does not apply to standby generators.But does the transfer switch have to be listed for use with fire pumps? The code is not clear.
Thank You
James Crandall
