scotthager
New member
I have a fire pump application that is rather unique and I am curious as to how I should handle the application.
The fire pump is being utilized in a township pump house to help create a higher pressure to fire hydrants for fire fighting and not supplying a sprinkler system. Pressure sensors will be in piping and will tell pumps when to turn on or off to maintain the necessary pressure. 2 seperate pumps are being designed to maintain the town water pressure.
Will I need to size the OCD per the locked rotor current of the fire pump and the other two pumps in that room? Building is being backed up with an emergency generator. Can I size a seperate ATS per locked rotor of fire pump and run rest of building off second ATS sized per motor full load current?
I have never used a fire pump for this application and any advice would be appreciated.
