It appears as if this section does not intend for OCPD's between the generator and the fire pump to be sized per locked rotor amps of the pump and associated equipment, but the final sentences seem to contradict that. "All disconnecting devices and overcurrent protective devices that are unique to the fire pump loads shall comply with 695.4(B)(1) through (B)(4).
