powerplay
- In front of a computer.
In a one level strip mall with wooden trusses and steel studs between suites, the walls are double 5/8" drywalled and not considered a firewall, but a fire separation? The ceiling has double 5/8" drywall also...just curious if anyone has thoughts or seen issues that arise from cutting in steel boxes in the ceiling attached to wooden supports to flush mount ceiling lighting(if that's allowed), and using non-metallic sheathed cable through steel stud with grommets, passing through into the new wooden wall firechaulked within the suite. I have pulled in armoured cable to add peace of mind, but am curious, as I have been informed that non-metallic sheathed cable may pass through the separation wall between suites, firechaulked into the wooden wall within the new suite.
On another note, in a three story duplex with sprinklers, I have been informed that the local building code will allow a single gang box in the separating common wall between suites. Are there any online references that anyone knows of? I have been on another site that has commercial building references, but have been waiting for almost 3 days for an response. Local authorities have different interpretations, and it would be nice to hear some opinions?.. thanks again!
