sfav8r
- San Francisco Bay Area
We have been told by local inspectors that if we are adding remodel cans to an existing room where that is the only work being done, that we can add the cans and there is no requirement for a fire rating.
Other inspectors say that if you made a penetration, you have to make sure it's rated. The group that says it must be rated are split into two categories. One group says stuff a fire hat in the hole and put the light in and you're done, the other group says there is no way to assure that the hat is properly seated when you do that.
Any code references on this? I'd like to read through the building code and see what the deal is. My personal belief is that they are correct about the seating of the fire hat, but I'm not sure about the requirement of the rating to begin with in a remodel situation.
Any references would be appreciated.
Thanks.
Thanks.
