In the definitions section of Utah's Electricians Licensing Rules (http://www.dopl.utah.gov/laws/R156-55b.pdf ) section 102(1) it states
Electrical work does not include. . .
"cable-type wiring that does not pose a hazard from a shock or fire initiation standpoint as defined in the NEC. Wiring covered by the NEC that does not pose a hazard as described above includes class 2 wiring as defined in Article 725, Power-Limited circuits as defined in article 760 and wiring methods covered by Chapter 8. Other wiring, including wiring under 50 volts is subject to licensing requirements."
My questions are:
1. In non-code terms, what types of wiring/currents/applications does the NEC consider to "not pose a hazard from a shock or fire initiation standpoint"?
2. Do typical low voltage outdoor lighting systems fit into this category?
Thanks for your help.
My questions are:
