The primary local jurisdiction has always required a 4 hour rated fire wall separating occupancies in order for the the structure to be considered separate buildings allowing two services.
A new occupancy addition is being built to an existing building in a different jurisdiction and the building inspector states since it is a Class 5 construction he only requires a two hour fire wall to consider it a separate building.
Having not dealt with building codes I have always thought the 4 hr wall was a requirement. Cans some of you with knowledge of the requirement enlighten me.
