Fire water pump room help!
Hey guys,
I am wiring a fire water pump room and a bit confused. All of the devices in the room are wired from a simplex IAM, addressable module. All from the same IDNet. My prints show 4 pump controller points, which are easy to locate NO contacts. The 8 remaining points are "fire water pump room points" and have no information outside of a name and address.
There doesnt appear to be anywhere to make connections, other than 4 valves. Does anybody have any knowledge as to where a connection would be made for "jockey pump fault" , "heat trace", "tank heater" and "tank water level low" outside of the controller?
Cheers! Sorry if anything is unclear!
My guess is a screen interface for the Simplex IAM will show label names for each connection point, and symbols will reference a legend for your specific-status monitors.
Or, maybe your Simplex IAM is missing 4 points, or maybe fire-pump rooms operate in pairs with 1 point each, primary & backup.
