goldstar
- New Jersey
- Electrical Contractor
Here in NJ we are now required to have carbon monoxide detectors in hallways outside bedrooms. I've been using the Firex combination smoke and carbon monoxide detector for 2 reasons :1) they're interconnected with all other devices on the circuit and 2) you don't have to put a second device on the ceiling or plugged into a receptacle in the hallway.
So far, I've had 7 of these malfunction (3 of which were replaced twice and in the same residence) and trigger for no apparent reason. Now, I'm not knocking Firex, but has anyone else been having problems with these and if so, what was the solution ? Firex's solution was to replace the combo units with std. smoke detectors and sent separate plug-in units for the hallway.
Also, it is my understanding that carbon monoxide travels lower to the floor level rather than at the ceiling. If that theory is correct why would manufacturers make combination detectors ?
