TRAVIS LATIOLAIS
This is the first time i use this forum. Any response will be greatly appreciated. If i run 2 hots and a ground to a single phase 240volt motor, then i tap off 1 leg and run that leg and a neutral to feed lights and outlets. I will use a 2 pole 20amp breaker in panel. If something goes wrong with the lights or outlets, will the double pole breaker trip?
